GE HealthCare - Diamond
by GE HealthCare
The award-winning Diamond began with a process of analyzing and understanding the key elements involved in breast healthcare. Its intuitive design started with clinicians and patients and then focused on the human touch that is required in the delicate field of breast imaging. With this approach, the Diamond becomes an extension of the user’s thoughts and actions.
0RepliesSat Apr 13 2024 | Errors 0075 and 0077 I am facing the communication errors 0075 "Bus-Comp hardware failure" and 0077 "Bus-Coll hardware failure". It seems like a common failure, so I checked the communication cables: between the supervisor and Stereo PCBs, the cable between the Stereo and Collimator PCBs, the cable between the Stereo and Compressor PCBs, all three cables gave good continuity. The communication indicator LEDs (RXD, TXD) on the supervisor, Stereo and Compression PCBs are dimly lit, but on the Collimator PCB the LEDs are off. It appears that the Collimator PCB is bad, but the unit indicates two errors from two different devices (Collimator and Compression) as if it were a common problem on the Stereo or Supervisor cards. I really appreciate the help on this. Greetings. Reply |
0RepliesTue Mar 26 2024 | Service Manual Hi. Every one I need GE diamond memoghraphy service manual Any one have service manual Please send me Equipment: GE Diamond Memoghraphy Reply |
1ReplyMon Jul 27 2020 | Ge Diamond Error Hi , has anyone got some information on the system. especially the error codes. i have a GE Diamond mammo on startup does a few tests then seems to have a loud noise out the tube head and an error comes up on the Display console: ER0015* Col-Rear Rear Collimator fail Any help would be appreciated. Reply |
[list] [*] AutoPoint Helps you Get it Right First Time [*] Diamond brings new intelligence to breast imaging. AutoPoint digitally analyzes breast composition and structure. [*] PaddleLogic senses which paddle the operator has selected and the detectors used are only those under the compressed part of the breast. [*] AutoPoint analyzes the compressed area of the breast and Diamond collimates automatically to the correct field size for each paddle. [*] Autopoint selects the correct AEC detectors at the beginning of the exposure. [*] Diamond has 8 discrete detectors with optimized sizes, location and shapes for optimal results, especially on the dense parts of the breast. Automatic or manual selections are both possible. [/list]
| Mammography Type | Analog X-ray |
