LIARRE - Neptune and Neptune Print
by LIARRE
NEPTUNE PRINT is an autoclave with a vacuum pump suitable for the sterilisation of both S2 and N type loads.
1ReplyTue Jul 02 2019 | Pump Not working Water Refiiling by pump not working. No Suction of water when Pump key is pressed. Please if you can provide service manual and where can I order pump for this machine. thanks in advanceReply |
1ReplyWed Jul 19 2017 | NEPTUNE PRINT Hi We had imported Neptune Print from Liarre. Now it appears that the company is non-existant The new autoclave is showing error AL-400 and only two programmes are running and are on display. We urgently need display board PCB for the neptune plus and also repair/maintenance maual. rgds rajnish bhatia alb surgicals p ltd 3/18, west patel nagar new delhi 110008 indiaReply |
0RepliesTue Oct 08 2013 | Liarre Neptun Print 15 Hello .You can order and buy accessories and spare parts for autoclave Liarre Neptun Print 15 Reply |
[list] [*] Medical device (Directive 93/42/CEE) class IIa [*] Capacity 15 litres. [*] Chamber depth of 35,6 cm [*] All functions are microprocessor controlled. [*] The closing and locking of the door is completely automatic [*] Easy to use thanks to the large graphic display and symbols. [*] Built-in printer. [*] The autoclave can be connected to the mains water system through a water demineraliser (accessory available separately). [*] 10 cycles for wrapped and unwrapped instruments [*] 2 test cycles [*] Automatic drying [*] Model with built in printer and capacity 23 lt. [*] Chamber depth of 51,5 cm [*] Model without the printer, with connection RS232 [/list]
| Orientation | Benchtop |
