LIARRE - Athena 15 and 23
by LIARRE
Athena 15 and 23
Simple and low cost, ATHENA is a thermodynamic vacuum autoclave suitable for N type loads.
FORUMSView All (3)
-Didie
Sun Dec 15 2019
Autoclave Athena 15
Hello, My Athena 15 autoclave starts but for a few minutes it displays the message al0504 and does not want to build up pressure or temperature. I no longer have the user manual. Do you have a solution please. Thank you Reply
-Rahmat Bruer
Fri Jul 03 2015
no suction tube
I have repaired the Athena 23 at authorized distributor: PT Mandiri Jaya Medika, Jakarta-Indonesia.
with reason the old version of Athena 23 discontinued product, I have not received the suction tube to fill water in the internal tank. please send the suction tube for old version made in 2012
-reiska
Tue Sep 09 2014
AL0101
terdapat pesan AL0101 pada layar athena 23,mohon kirim user guide atau solusinya
[list]  [u]ATHENA 15 [/u]    [*] Medical device (Directive 93/42/CEE) class IIa     [*] Capacity 15 litres.     [*] Chamber depth of 35,6 cm     [*] All functions are microprocessor controlled     [*] Liquid crystal display with water level indicator     [*] 4 cycles for wrapped and unwrapped     [*] Double door control sensor     [*] Automatic drying      [u]ATHENA 23[/u]     [*] Capacity 23 lt.     [*] Chamber depth of 51,5 cm  [/list]
OrientationBenchtop
