MELAG - Vacuklav 40-B
Tap-water connection necessary Chamber depth: 35 cm, 18 litres.The Vacuklav 40-B works with a fractionated pre-vacuum and satisfies the requirements to “Class B”- autoclaves of the European standard EN 13060. The deep vacuum is created by a very high performance electrical vacuum pump. The deep post-vacuum ensures optimal drying of wrapped materials and large quantities of wrapped textiles and porous goods as well. The installation of the Vacuklav 40-B is therefore as simple as that of a washing machine.
The Vacuklav 40-B can be connected with the water treatment system MELAdem 40 or MELAdem 47 to a water source and drain. A part of the tap water will be demineralized and used for the steam generation, and another part is used to cool the vacuum pump.
The required documentation of the sterilization cycles is carried out over the built-in network interface. The data can be stored directly on the practice network. It is also possible to print the data with the protocol printer MELAprint 42 or store the data on the MELAflash CF Card. The sterilization records can be read out on every PC with the MELAflash CF Card reader.
Two helix reference block systems, the MELAcontrol and MELAcontrol PRO are available for the verification of successful sterilization in a class B autoclave.
The batch control can very easily and low-priced be carried out with the Helix test specimen MELAcontrol. The documentation of the release is carried out with the MELAdoc system, consisting of the documentation pages and the MELAdoc label printer for sterilization packagings.
Vacuklav autoclaves are delivered with a mount for trays or cassettes included in the price of the autoclave. Combi mount C (for 6 trays or 3 standard-tray-cassettes) will be delivered as standard. Likewise different sterilization containers are available.
0Replies7 years ago | Melag 40 B Spare parts I need producers item code for the following parts: vacuum pump Door lock Send to my e-mail: nina@dentalia.no Kind regards Nina E GullaksenReply |
- Speed - Because unwrapped handpieces can already be removed from the autoclave after 10 minutes in the quick program with fractionated pre-vacuum, including drying time, wrapped handpieces already after 17 minutes
- Comfort - Documentation alternatively with MELAflash CF Card, directly into the network or with protocol printer MELAprint 42.
- Design - The extra large graphic display makes operating a pleasure and gives additional tips and information.
Chamber Volume | 18 L |
Height | 56 cm |
Chamber Height | 35 cm |
Length | 57 cm |
Orientation | Benchtop |
Weight | 56 kg |
Chamber Depth | 25 cm |
Width | 46 cm |
Tray: Width: 19 cm, Depth: 29 cm, Height: 2 cm,
