MELAG - Vacuklav 41-B
by MELAG
MELAG Vacuklav 41-B
[b]No tap-water connection necessary Chamber depth: 35 cm, 18 litres [/b]             The Vacuklav 41-B is a "stand-alone" autoclave with built-in water storage tank and works with a fractionated pre-vacuum and satisfies the requirements to “Class B”- autoclaves of the European standard EN 13060. The deep vacuum is created by a very high performance electrical vacuum pump. The deep post-vacuum ensures optimal drying of wrapped materials and large quantities of wrapped textiles and porous goods as well.               The Vacuklav 41-B can be connected with the water treatment system MELAdem 40 or MELAdem 47 to a water source and drain as an option.
-Sterry
Thu Apr 06 2017
Engineer pass code
I am looking for the engineers code or better still the technical manual for this machine. Anybody help?Reply
[list]  [*] Speed - Because unwrapped handpieces can already be removed from the autoclave after 10 minutes in the quick program with fractionated pre-vacuum, including drying time, wrapped handpieces already after 17 minutes       [*] Comfort - Documentation alternatively with MELAflash CF Card, directly into the network or with protocol printer MELAprint 42.  [*] Design - The extra large graphic display makes operating a pleasure and gives additional tips and information.  [/list]
Chamber Volume18 L
Height56 cm
Chamber Height35 cm
Length 57 cm
OrientationBenchtop
Weight58 kg
Chamber Depth25 cm
Width46 cm
Tray: Width: 19 cm, Depth: 29 cm, Height: 2 cm
