MELAG - Vacuklav 30 B+
Steam Sterilizer
The Vacuklav 30 B+ is a class "B" autoclave according to the European standard EN 13060 and therefore absolutely fit for the future. It works according to the fractionated pre-vacuum method. This means: At first the air is evacuated from the chamber with a very effective vacuum pump. Then there is a repeated intake of steam which is always immediately pumped out again. The result is that at the beginning of the actual sterilization, there is no longer any air in the chamber or in wrapped hollow instruments or in textiles which would endanger the success of the sterilization. The Vacuklav is equipped with a fractionated post vacuum for effective drying as a prerequisite for long-term storage of wrapped sterilized materials. Sensors and an innovative microprocessor control regulate and monitor the parameters pressure and temperature necessary for a secure sterilization.
1Reply2 years ago | User manuaö User manual Reply |
Chamber Volume | 18 L |
Height | 48.5 cm |
Chamber Height | 35 cm |
Length | 57 cm |
Orientation | Benchtop |
Weight | 44 kg |
Chamber Depth | 25 cm |
Width | 42.5 cm |
Tray: Width: 19 cm x Depth: 29 cm x Height: 2 cm
