MELAG - Vacuklav 23 B+
MELAG Vacuklav 23 B+[b]No tap-water connection necessary Chamber depth: 45 cm, 22 litres[/b] The Vacuklav 23 B+ is a ”class B" autoclave according to the European standard EN 13060 and therefore absolutely fit for the future. It works according to the fractionated pre-vacuum method. This means: At first the air is evacuated from the chamber with a very effective vacuum pump. Then there is a repeated intake of steam which is always immediately pumped out again. The result is that at the beginning of the actual sterilization, there is no longer any air in the chamber or in wrapped hollow-instruments or in textiles which would endanger the success of the sterilization. The Vacuklav is equipped with a fractionated post vacuum for effective drying as a prerequisite for long-term storage of packaged sterilized materials. Sensors and an innovative microprocessor control regulate and monitor the parameters necessary for a secure sterilization pressure and temperature.
FORUMSView All (8)
1Reply5 years ago | Mulfunction 1 vaccume system What is the action if this massage is appearing in the unit "mulfunction 1 vaccume system"? Reply |
1Reply7 years ago | vacuklav our door suddenly will not close for us, has not been damaged in anyway, can u help??Reply |
4Replies7 years ago | no feed water i read the solution if no water feed ,check solenoid,cleaned water tank,cleaned all filter,check of internal/external water setup but still no feed water appear at the display cant you tell me what other solution ...... Reply |
Chamber Volume | 22 L |
Height | 48.5 cm |
Chamber Height | 45 cm |
Length | 72 cm |
Orientation | Benchtop |
Weight | 49 kg |
Chamber Depth | 25 cm |
Width | 42.5 cm |
Tray: Width: 19 cm x Depth: 42 cm x Height: 2 cm
