Midmark - Ritter M11
Autoclave
The M11 is the largest member of the Ritter family of autoclaves. Its unique 11" x 18" chamber gives it the distinction of having the largest sterilizing capacity of any standard countertop sterilizer on the market, making it perfect for larger packs and instruments. Features include:
FORUMSView All (14)
4Repliesa year ago | Items do not not completely dry Hello. I am having a problem with the sterilizer not completely drying the items. I have checked the filters which were not clogged. The gasket was recently replaced prior to my arrival. Thank you.Reply |
2Replies2 years ago | Water disappearing from chamber during cycle? Hello, I'm working on a 2003 Midmark M11 Sterilizer. Recently it began shutting off mid cycle due to the overtemp switch. When I checked the chamber, there was no water. I verified water is entering the chamber at start, but by the time the cycle is almost complete, water is gone. I found that the water is being pushed back through the "Vent" valve once pressure exceeds 10 psi. Needless to say, I think I have found the problem. The valve and solenoid are 20+ years old, would you replace both with RPI new, or just repair the valve with new seals? Bonus question, why are there two possible choices for the RPI vent valves when there is only one Midmark part number listed? It says to see if the old solenoid label says "FWR" on it. Stands for F= FULL, W= WAVE, R= RECTIFIED. RPI says you MUST get the correct replacement part, but the label is worn out on my old one? How to tell the difference without label.Reply |
1Reply2 years ago | user manual I need a copy of the user manualReply |
[list] [*] Exclusive automatic-opening door for ease of use and a quick drying time [*] Large 11" by 18" chamber for increased capacity [*] SteamFlush Pressure Pulse Air Removal System ensures proper steam penetration [*] Self Program Controls enable you to create different cycle parameters to meet specific instrument processing needs [*] Pre-Programmed Controls for convenience [*] LCD Display for easy view of indicators [/list]
Chamber Volume | 24.6 L |
Internal Diameter | 11 in |
Height | 17.8 in |
Length | 23.8 in |
Orientation | Benchtop |
Weight | 99 lbs |
Chamber Depth | 18 in |
Width | 17.8 in |
Trays: [i]Two large[/i] 9" W x 15" L x 1.1" D (22.9 cm x 38 cm x 2.9 cm) [i]Two small[/i] 6.6" W x 15" L x 1.1" D (16.8 cm x 38 cm x 2.9 cm) Shipping weight: 131 lbs. (59.4 kg) Water reservoir capacity: 1.4 gal. (5.3 liters)
