Midmark - Ritter M7
by Midmark
The speedy M7 autoclave is the perfect choice for anyone looking for an effective, manual sterilizer...at an unbelievably low price. It sterilizes both wrapped and unwrapped instruments, linen packs and glassware. From a cold start, unwrapped instruments take only 111/2 minutes...starting hot, it’s just 9 minutes! The M7, the “workhorse of sterilizers,” is an investment that will last…and last.
1ReplySat Oct 26 2024 | Maintenace weekly monthly guide Hello do you have training materials for weekly monthly yearly maintenace Equipment: ritter m7 Reply |
1ReplyThu Oct 17 2019 | missing a hose to drain unit I have a very old Midmark Ritter M7 Autoclave. It seems to be missing the hose to drain the unit. The unit I suspect is about 25 years old. Does anyone know if it is possible to get a hose for this unit?Reply |
6RepliesMon Apr 07 2014 | shuts down during operation unit did this a few times but is now working, no problems when I was present Reply |
[list] [*] Safety Door The safety door on this autoclave automatically seals when pressurized and will not allow the operator to open the door until the chamber is safely depressurized. [*] Temperature Regulator The temperature regulator allows the operator to preset the temperature at a desired setting between 250º F (121º C) and 270º F (132º C). This control, acting as a thermostat, cycles the heating element on and off. [*] Temperature Gauge The temperature gauge indicates the temperature inside the chamber. The gauge is graduated in two-degree increments from 80º F (26.7º C) to 270º F (132º C). [*] Low Water Cut-out Switch The low water cut-out switch prevents “dry burning”. The M7 autoclave will operate only when there is enough water present, which prolongs the life of the heating element. A pilot light is on when the heater is on and cycles on and off during normal operation. [*] Cycle Timer The cycle timer regulates sterilization time from 0 to 30 minutes and automatically turns the M7 off when the sterilization cycle is complete. This prevents over-sterilization thus extending the service life of your instruments. [*] Front Draining Feature With our front draining feature, it's easy to clean and maintain. All controls and information are on the front and easily accessible to the operator. [/list]
| Chamber Volume | 9 L |
| Internal Diameter | 7.5 in |
| Height | 13 in |
| Length | 19 in |
| Orientation | Benchtop |
| Weight | 30 lbs |
| Chamber Depth | 15 in |
| Width | 14 in |
Countertop area: Minimum depth 16.5" (41.9 cm) Trays: [i]Two large[/i] – 12" L x 5.62" W x .88" D (30.5 x 14.3 x 2.2 cm) [i]One small[/i] – 12" L x 4.12" W x .88" D (30.5 x 10.5 x 2.2 cm) Water reservoir capacity: 1.31 gal. (4.9 liters) Electrical Requirements: 115 VAC, 60 Hz, 10 Amps Single Phase 115 VAC has 1136 watt tubular immersion heater 230V, 50H, 5 Amps Single Phase Installation: Use this M7 autoclave on laminate, stainless steel or stone surfaces. Allow 2.0" (5.08 cm) on sides and rear and 12" (30.5 cm) above, to allow space to fill the reservoir and for cooling processed trays.
