MMM - Vakulab PL
by MMM
Large scale sterilizer for the sterilization of solid, porous and liquid goods in hospital pharmacies. If required, the sterilizer can also be equipped with a fan to achieve faster cooling or to sterilize liquids and firmly closed receptacles. In animal, pharmaceutical or biomedical research as well as hospital pharmacies need a sterile environment. Growing media, solutions in open or closed recepticals, pathogenics samples, solid and porous or pressure sensitive goods, contaminated material, filter, animal cages, fodder, food etc. are the range of items sterilized by Vakulab PL: fast, perfect, cost-efficient and reliable.
[list] [*] Short cycle times [*] High sterilization safety [*] Fast cooling [*] Customized cycle parameters [*] Loading heights of either 625 mm or 390 mm [*] Direct inlet of clean steam into the chamber [*] Chamber and frame are made of stainless steel [*] Great program variety [*] Customized cycle parameters [*] Validated software [*] According to standards DIN 58951 or 58950 [*] Low energy and water consumption, low operating costs [*] Option: mirror polished [*] Option: fan driven by a magnetic clutch [*] Option: steam-air mixture process [*] Option: hot water sprinkling process [*] Option: air tight sealing off made of stainless steel [*] Option: H2O2 connection for the disinfection of heat sensitive items [/list]
| Orientation | Floor Standing |
