MMM - Fluipharm
by MMM
MMM Fluipharm
Tailormade steam sterilizer with more than 4 STU for fast and reliable sterilization of instruments, utensils, linen, plastics and complicated MIS instruments as well as other medical devices in health care facilities such as hospitals, clinics and industrial sterile supply providers.        [b]Proven Technology - Individual Construction[/b]         Your research, goods, and demand of sterilizers are unique – unique is the result that we deliver: the perfect conjunction of proven MMM technology and customer specific requirements. Based on your specifications we will design and manufacture a quality product corresponding to your demands in every detail, taking all necessary regulations (cGMP, GAMP, FDA etc) into account.                  [b]Superior Human Machine Inferface for Intuitive Operation[/b]         The sophisticated MMM touch screen HMI uses the Siemens latest generation multipanel for intuitive operation. The large 10“ colour display delivers all the relevant process information at a glance: current batch information, machine status, process stage, remaining cycle time, clear messages in case of errors and deviations from the desired set points etc..                  [b]Hygienic Design for critical Areas[/b]         The pressure vessel, the electrically driven sliding doors and all the process pipe work in contact with the product are made from stainless steel (CrNiMo, material number 1.4404 or 1.4435/AISI 316L). For operation purposes requiring the highest level of hygiene we are able to deliver the chamber with the inner surface polished. All associated process valves and pipe work are also constructed to meet the highest level of hygiene, sanitary valves are available. All connections, optionally clamp or aseptic screwing, are assembled by orbital welding technique. Weld logging and boroscope inspection are available if required. Of course, all joint sealer and lubricants used are conforming with the requirements of FDA (21 CFR). By means of modern measuring technology according to Hygienic Design requirements, all parts in contact with the product or the product environment are fully drained back to the chamber.                  [b]Performance Boosters for More Efficiency[/b]         The extremely short cycle times result from the large capacity circulation pump, which is able to move a significant amount of water in a very short time via a plate heat exchanger, heating the water by means of inexpensive process steam. The plate heat exchanger is optimized for its use in the extremely sensitive field of pharmaceutical application as its secure construction avoids any possible contamination of the sterilization water.
[list]        [*] Custom-made construction         [*] Program design according to individual purpose         [*] cGMP conformity         [*] Short cycle times         [*] Use of inexpensive process steam         [*] High-power circulation pump         [*] Efficient heat exchanger          [*] Vacuum programs if required         [*] Air tight barrier, made from stainless steal          [*] Gentle treatment of the goods         [*] Fresh water saving of up to 100 %          [*] Versatile application        [/list]
OrientationFloor Standing
