MOCOM - MILLENNIUM B
by MOCOM
MOCOM MILLENNIUM B
Millennium B+, Millennium B² and Millennium B are Mocoms revolutionary step forward in the field of type-B steam sterilizers. They represent an ideal point of reference in terms of safety, performance and flexibility.              The menu offers a wide range of programs, specifically developed for a suitable treatment of the various materials. Different combinations of the vacuum pulses, temperature and process time, duration of drying, allows the efficient sterilization of each type of load.              The advanced sterilization process self-evaluation system, allows an accurate cross-referenced control of the basic parameters of sterilization. It also signals any failures throughout the whole process, and it provides the user with the most fundamental guarantee: that of total safety.
FORUMSView All (7)
-WaseemKhan
Tue Oct 14 2025
The autoclave displays H150 error
Hello members, I have MOCOM Millennium B autoclave unit from a client. When I switch it on, the buzzer on the circuit beeps for a while and it displays the error "MPX Broken Now Leveling H150". I have checked the error message in the service manual and also replace the pressure transducer but still the same problem. The values of temperature and pressure on the display are also weird because they are changing to some random values. Sometimes pressure of 9 bar is shown and temperature of 500 roundabout is shown.
Kindly, someone guide me here. I would be really thankful to you.
Equipment: MOCOM Millennium B Autoclave
-kostai
Thu May 15 2025
STUCK AT LEVELING POROUS
Hi guys, if have a millennium B with a problem at the end of the cycle before ending, any ideas what to check. I have cleaned EV1-2-3-4 and the filters.
-andex76_9503
Fri Jul 09 2021
Mocom Millenium B errors h410 a260
Hallo, I have problem. This autoclave Mocom Millenium B stay 1 year without working . 3 days ago it had problem with errors a260- I clean chumber filter- was realy dirty, 2 sterilisation process was good, and now it has h410 error. The chumber filter is clean now. It has also realtime clock baterry low, I'm waiting for new one M48T86PC1. Anyone knows??Reply
[list]      [*] Type B conforming to prEN 13060: 2002       [*] Capacity 17 litres       [*] Microprocessor controlled electronics       [*] Instant patented steam generation system       [*] Fractionated vacuum system to ensure the complete removal of air       [*] Customized vacuum drying       [*] Advanced multilingual software       [*] Stainless-steel sterilization chamber       [*] Robot-controlled locking system       [*] Integrable optional printer       [*] Integrated water filling and draining tanks       [*] Wide range of sterilization programs       [*] 3 standard trays provided      [/list]
Chamber Volume5.5 L
Chamber Width310 mm
Height310 mm
Chamber Height80 mm
Length 375 mm
OrientationBenchtop
Weight35 kg
Chamber Depth220 mm
Width545 mm
