MOCOM - EXACTA
Autoclave
The steam autoclave with pump generated pre-vacuum, vacuum drying and rapid cycle times.
FORUMSView All (45)
1Replya year ago | Mocom Exacta Vacuum Hello. I have a Mocom brand Exacta Vacuum (autoclave) steriliser. Even though I take all the care, it doesn't sterilise. I set the temperature to 134 degrees Celsius. When the temperature reaches 105 degrees, the "Alarm" lamp turns on and the cover of the device is opened. What could be the reason? I would be glad if you could help with this. Best Regards... Reply |
1Replya year ago | out of order because locking problem locking problem alarm A022 Equipment: MOCOM - EXACTA S Reply |
2Replies3 years ago | Service Manual Error code Reply |
- Total management using a Micro-Processor - To ensure constant monitoring of the parameters and precise control of all the autoclave's functions.
- Combined pump generated pre-vacuum system - Extracts air efficiently producing optimum steam saturation and penetration in the hand pieces and turbines too.
- Combined vacuum drying system (Mocom patent) - Combines the extraction action of a vacuum pump with pressurized air ventilation introduced via a bacteriological filter.
- 9 Pre-set cycle
- Easy-to-use
Orientation | Benchtop |
