Calimaster - Maico MA 25
by Calimaster
Accurate audiometry in the palm of your hand
Sleek, small design. The super lightweight MA 25 weighs in at only 3.6 lb/1.6 kg. Small enough to hold in the palm f your hand! Tucked into its carrying case (included), the MA 25 is our smallest, lightest portable.    Accurate, dependable engineering. Because it’s a portable, the MA 25 is engineered to be tough and reliable. Take the MA 25 anywhere with confidence. User friendly over sized knobs make adjusting frequency and hearing levels easy. Simple push button operation for right/left, pulse tone and warble.    Although the MA 25 is small, it offers a full range of testing opportunities. Frequency levels range from 250 Hz to 8000 Hz, and signal intensities run from -10 dB HL to 90 dB HL.                   To provide you with more versatile testing opportunities, the MA 25 is powered by either a 9V battery or an optional AC adapter. Work in the office or test on the go for maximum efficiency
-JILL
Wed Dec 14 2011
MA-25
Is the MA 25 pictured on your website a newer model of an older design?  Someone is trying to sell me an MA -25 but it doesn't look like yours or any other I can find online.  They have an MA-25 owner's manual right beside it in the photo, but the unit itself looks much different...
[list]        [*] Air conduction         [*] 9V battery operated, optional AC adapter         [*] Continuous, pulse, warble tones         [*] Exceptionally lightweight        [*] Carrying case included        [/list]
Weight3.6 lbs
