GE UTC Fire & Security - DirecDoor
by GE UTC Fire & Security
The DirecDoor controller from GE Security is the industry’s only 2-reader and 2-door Power over Ethernet (PoE) IP-connected access controller. DirecDoor integrates with GE’s Facility Commander WNX, Secure Perfect, and Picture Perfect access control and integrated security management software. It can utilize PoE or can be powered by a local power supply. It can even power the lock hardware in its PoE configuration. Its simple plug-in installation significantly reduces labor costs and allows new doors to be efficiently controlled using on-line access systems. The DirecDoor controller is located on the secure side of the door, thereby providing a much better IP solution than an IP reader. Unlike a less secure IP reader solution, whose Ethernet port, card database and access to the door strike relay lie outside the protected area, the DirecDoor controller significantly reduces the possibility that security could be compromised.
[list] [*] On board 2-readers with 2 door lock relays: low cost and easy installation [*] Support for Weigand and Supervised F/2F: flexibility to use GE Security and other readers [*] Intelligence at the edge of the network: database, network connections and lock control connections at the secure side of the door [*] PoE and local power supply support for controller and locks: requires fewer terminations resulting in time savings, lower product and installation cost; back-up power for network also backs up controller and locks [*] Fire panel alarm connection: for additional safety, the DirecDoor controller can be hard-wire connected to the fire alarm system to release door strikes [*] Integrated configuration tool based on Web server: remote configuration and ease of set up [*] Lower total cost of ownership in low density door environment: allows new doors to be controlled in a cost effective manner [*] Integrates with Facility Commander Wnx, Secure Perfect and Picture Perfect software [/list]
