Zimmer - ATS 3000
Tourniquet
The A.T.S. 3000 Automatic Tourniquet System is a dual-port, dual-cuff system with microprocessor controls and dedicated ports for supplying and measuring pressure independently. With the innovative Limb Occlusion Pressure (LOP) feature, the A.T.S. 3000 Tourniquet combines the latest in advanced tourniquet technology with the well-established Zimmer tradition of safety, reliability, and convenience.
FORUMSView All (9)
0Replies18 days ago | Zimmer ats 3000 I have a summer ATS 3000 does not work on AC supply but works OK DC battery volts. There's no green indicator light. Can any one provide me with a schematic diagram? For the power supply section. Tq Reply |
1Reply3 years ago | Torniquete ¿Qué tipo de manguito se usa para este equipo? ¿Tiene en existencia ? Reply |
1Reply4 years ago | Tarjeta control - Pantalla LCD Alguien sabe o pueden venderme la pantalla LCD y la tarjeta de control del ATS 3000, cuando encendemos el torniquete quirúrgico la pantalla no enciende y suena una alarma y no para sonar. ¿Alguna sugerencia? Reply |
VIDEOS
- Innovative Limb Occlusion Pressure(LOP) feature.
- Uses ambient air.
- Uses electronic and microprocessor regulated pressure.
- Self-Check Calibration automatically checks the accuracy of the machine calibration each time the unit is powered on.
- Cuff Alert alerts the user of cuff status when an attempt is made to set the machine on standby.
- Cuff Lockout feature prompts the user to confirm the deflation command during bilateral or IVRA procedure in order to reduce complications due to sudden cuff deflation of the second cuff.
- Height: 13” (33.02 cm)
- Width: 9.5” (24.1 cm)
- Depth: 10.4” (26.4 cm) (Including clamp and ports
- Weight: 16.3 lbs (7.4 kg)
- Mains Line Voltage Range: 100–240V ~ (AC), 50/60 Hz. Auto switching
- Line Current: 670 mA RMS @ 120V ~ (AC)
- Input Power: 53 Watts typical
- Battery Type: Rechargeable, 12 VDC sealed lead acid, 4.0 amp hours
- Battery Discharge Time: Unit will operate on battery power for 240 minutes minimum with a fully charged battery.
- Battery Recharge Time: 24 hours. The unit should be plugged in 24 hours before initial use.
- Power Cord: Type SJT, AWG 16, 14 ft. (4.27 m)
- Power Plug: Hospital grade, 3-prong straight blade, 15 amp
- Line Protection: 2 time delayed 1.0 amp 250-volt fuses
