ResMed - S9 AutoSet
by ResMed
S9 AutoSet combines an intelligent algorithm with Easy-Breathe expiratory pressure relief (EPR) to dynamically adjust pressure for maximum comfort.
Using ResMed's time-tested APAP technology, AutoSet continually monitors breathing, adapting breath-by-breath to always deliver the lowest therapeutic pressure, improving comfort and sleep.        Enhanced AutoSet is now able to differentiate between obstructive and central sleep apneas, so you can be confident that you are always receiving appropriate therapy and pressure.
FORUMSView All (7)
-Nucu
8 years ago
Error 1018
Hallo! Please help me! What means "error 1018" to ResMed S9 AutoSet II? Thank you verry, verry much!Reply
-anthony1
10 years ago
dry skin
hi
i have used the resmed s9 for a  year with no problems,however just recently ,i have dry  skin around the area of the  nasal mask,causing me facial marks,can anybody help or having same  problems please.
anthony
-Jean-Marie
12 years ago
Electrical power device
Hello,
My name is Jean-Marie. I leave in France and have recently got a Resmed S9 Autoset machine.
Is's good except one thing: the electrical power device which is heavy. Moreover, I would like to use the same device for both my computer and the Resmed. This is because I frequently take the plane for the job. As you probably know, when you travel for business, you generally prefer not to put luggage in the aircraft hold: that's the reason why I tried to find a device able to do that and, fortunately, I found one which, moreover, is less heavy than yours. Here is a link to a webpage showing it
http://www.all-batteries.fr/alimentation/24v/3-75a.html#description
Only one problem remains: the connector of this power device is not adapted to the Resmed.
My question is consequently to ask you the reference of the plug connector on the cable, so that I can try to find an adaptor.
Thanks a lot by advance.
Regards.
JM Lesueur
lesueurjmh@yahoo.fr
[list]      [*] Climate Control       [*] SlimLine Tube       [*] Enhanced AutoSet       [*] Intuitive Disign      [/list]
