ResMed - VPAP ST
by ResMed
The system is compact and convenient, and out-performs bulky products offered by competitors. VPAP ST is ideal for travel or home use.
The system is compact and convenient, and out-performs bulky products offered by competitors. VPAP ST is ideal for travel or home use.             Featuring Easy-Breathe, ResMed’s exclusive comfort technology, VPAP ST offers nearly silent therapy and greater pressure stability so patients sleep comfortably throughout the night. VPAP ST uses Easy-Breathe pressure delivery and synchronizes with the patient’s normal respiration so that breathing feels more natural and comfortable.             The VPAP ST provides Spontaneous/Timed (S/T) therapy that allows the patient to breathe at their normal respiratory rate. If the patient experiences an apnea or falls below the set rate, the device supports the patient’s ventilation with a timed breath.              ResMed’s exclusive TiControl allows the clinician to customize therapy for acute conditions. Vsync technology compensates for mask leakage and provides consistent flow performance. VPAP ST features exceptional trigger and cycle sensitivity for customization at the beginning and end of each breath.             VPAP ST is the most versatile device available and is compatible with the S8 ResLink, H4i, ResScan and S8 ResTraxx.
-Shanraebeck
Sun Apr 29 2012
stops working
The machine will only work for a few minutes, then displays "check tube." We have checked the tube, finding no holes or any obstruction, but it will stop pumping air. No clue what to and of course it's a weekend and nothing in our area is open. Thanks.
-chuvso
Tue Nov 22 2011
The motor problem
I think the circuit control motor has a problem.
LCD display: Error system. Call service
And Could you give me service of machine?
I understand IC 66A405 and 66A406 and S2 UMI on circuit control motor.
[list]      [*] Compact, fully-integrated bilevel device for patients requiring a backup rate       [*] Designed to deliver exceptional customized patient-ventilator synchronization       [*] Combines high-performance noninvasive ventilation with quiet comfort of Easy-Breathe motor      [/list]
