Philips - SpeechMike Barcode
by Philips
The powerful SpeechMike Barcode with integrated Barcode Scanner allows you to attach patient or client information to your dictations and securely allocate the data to the relevant file. The SpeechMike Barcode retrieves information from Barcodes from a distance of up to 30cm/12?. The barcode scanner has an adjustable scan angle of 25, allowing two different position settings. The device integrates seamlessly with your IT system, truly raising the standard in terms of workflow efficiency. As well as a barcode scanner, the device also boasts advanced recording, editing, playback and navigation functions for greater dictation efficiency, documentation accuracy and data security. The dictation workflow has never been quicker or easier.
[list] [*] 4-Position Switch or push-button version for single-handed use [*] Dust-proof optical trackball and scroll wheel for precise navigation [*] Four fully programmable buttons for individual customization [*] Clearly visible LEDs indicate recording, inserting and overwriting modes [*] Ergonomic design is suitable for both right- and left-handed users [*] Dedicated button for recording of spoken instructions [*] Superb sound quality – ideal for speech recognition [*] Compatible with USB 2.0 [*] Scan directly into predefined fields for easy and accurate retrieval of barcode information [*] Clear assignment of dictations to corresponding file, greatly reducing the risk of error and increasing documentation accuracy [*] Ergonomic scanner activation through trigger at back of device [*] Adjustable scan angle of up to 25° for greater convenience [*] Seamlessly integrates with workflow systems, e.g. Radiology Information Systems, Hospital Information Systems or legal case management systems [/list]
