Olympus - DR-2000 EK
by Olympus
A perfect combination of professional features and a simple, portable design.
A perfect combination of professional features and a simple, portable design.      Its convenient button placement, easy slide switch operability and comfortable ergonomics allow you to utilize it for hours of consecutive use, while its durable construction ensures you'll be doing so for years to come. Included DSS Player Pro software helps you automate, streamline, and manage recorded files. A Directrec Configuration Tool in DSS Player Pro allows for easy button customization and other flexible uses.
[list]  [*] Slide Switch Operation - Quiet and easy to use slide switch results in high performance, comfort, and increased productivity.   [*] Customizable Programmable Buttons - DR-2000 has 3 programmable buttons that can be customized to suit particular program settings for a variety of purposes, recording conditions, and user environments.   [*] High Sensitivity Microphone - DR-2000 uses ø10mm, highly sensitive, built-in omni directional microphones. Microphone sensitivity can be easily adjusted using the included DSS Player Pro software to better adjust to various conditions including dictations or conferences.   [*] Programmable User ID - You can register an ID directly in the DR-2000. The ID will be used as part of the file naming of DR-2000-created dictations.  [/list]
