Hillrom - Integris 2002B headwall system
Headwall System
Hill-Rom is one of the largest hospital headwall manufacturers, offering several types of medical headwall systems and designs with different features and capabilities. The Integris® 2002B headwall system is available with multiple rails to extend its versatility to the positioning of electrical receptacles, low voltage devices and accessories. Moveable Gas Outlets – Gas outlet position and service can be customized with this medical gas headwall depending on changing needs.Standard 14-port Manifold – This headwall’s construction enables versatility. The manifold, which is located behind the gas panel, can accommodate a maximum of (4) oxygen outlets, (4) medical air outlets, and (6) vacuum outlets. Optional Integrated Bed Locator – The hospital headwall’s optional bed locator helps protect walls and equipment from damage.
0Replies9 years ago | new nurse call install unable to get system apart to access current nurse call to remove it and install new. Looking for a manual on removal of components. Reply |
0Replies9 years ago | Need specifications Reply |
