OxyHealth - Quamvis 320
Portable hyperbaric chamber
Designed to be tough and durable, these chambers provide added reinforcement while maintaining practicality and comfort.
[list] [*] Meets stringent PVHO Non-Mandatory Appendix ultimate strength requirement [*] 4 psi portable mild hyperbaric chamber [*] Pressure tested beyond 24 psi to exceed PVHO-1 safety requirements [*] 44 oz urethane bladder with proprietary SteelWeld seams [*] Extreme performance reinforcing ballistic nylon jacket with Lexan® mix viewing windows [*] External SafeSet buckling system for additional secure enclosure support [*] Designed for improved airflow throughout chamber [*] Rigid frame maintains form when deflated [*] Medical pass-throughfacilitates external device hookup [*] Clean air compressordouble head, oil-less, dual intake filters [*] High efficiency in-line filtration systemfilters to 0.01 microns [*] Bolster setcradles and stabilizes chamber when inflated [*] Custom mattresscontoured to fit inside the chamber [*] Chamber carry bag [/list]
Length | 93 in |
Inflated Diameter: 33 Inflated circumference: 109
