Invacare - Hydraulic Lift 450-1
Hydraulic Lift with Low Base - 450 LbsReliant Plus Lifts: The Invacare line of Reliant lifts was conceived to prevent caregiver back injury and to ensure dignity in patient handling. These high quality lifts are comfortable, reliable and an integral tool for staff and caregivers. Using the lift for patient handling reduces staff injuries, saving you money and reinforcing safety as a priority in your healthcare facility. Reliant Plus lifts support up to 450 pounds, making potentially challenging transfers smooth for resident and caregiver. The new higher lift range allows easy access to beds, chairs, toilets, floors, and tubs (with at least 4.5 inch clearance). Along with financial and innovative lifts, Invacare also offers facility assessment plans to further aid in your safety management program. Our all encompassing lift system may also include in-service training, videos, and an injury prevention program. Our goal is to partner with you in lowering costs and protecting your staff from injury. The sturdy and practical design of Reliant Plus lifts provides the solution you need for success in your quest to provide safe and effective health care.
[list] [*] Base legs adjust easily and lock securely into open position with the padded shifter handle - Total pinch-point protection covers all moving parts for added safety [*] Covered base provides protection against wear, dirt and moisture. [*] Height range allows lifting from floor and high surfaces. Padded swivel bar with 360 degrees rotation and six-point hookup allows use of Invacare chain-free slings as well as older-style slings with chains or straps. [*] Warranty includes three years on lift, one year on hydraulic pump. [/list]
Length | 48 in |
Weight | 93 lbs |
Width | 26.5 to 41 inches |
Weight Capacity: 450 lbs
