Liko - Likorall R2R room to room lift
From room to room with LikorallFrom room to room with Likorall
The need to transfer patients between different rooms is common in care and rehabilitation settings. Often, for practical or aesthetic reasons, it is not possible to install a rail above a door opening to enable these transfers. That’s why we’ve developed Likorall R2R.
Two Likorall R2R units are used to transfer a patient smoothly and safely from one rail system to another. Liko’s unique Quick-release Hook system makes the transfer safe for both patient and caregiver.
Likorall R2R is available in two models and several different versions. The lifts can also be equipped with a wide range of accessories.
2Replies6 years ago | noise but no movement I got a Liko Viking M patient lift. Batteries are fully charged. When i press the buttons on the handset, i hear a clicking sound but not movement. Neither the lift or the spreader works. Reply |
- Patented SFS safety drum (Single Fault Safety) with controlled lowering.
- Pinch guard SSP, Safety Squeeze Protection.
- Lift strap with a tenfold safety margin.
Lifting capacity: 440 lbs. (200 kg.)
