Liko - Free Span Straight Rail Lift
Mobile or stationary – the choice is yours FreeSpan SR is the flexible alternative for most stationary-lift situations.Mobile or stationary – the choice is yours FreeSpan SR is the flexible alternative for most stationary-lift situations. The lift system is freestanding, and since it is not affixed to the walls or the ceiling, there are no special strength requirements for those structures. FreeSpan is made of aluminum and many different rail lengths are available. Choose between Multirall and Likorall lift units. FreeSpan SR is assembled without tools. The lift system can be easily moved between rooms. FreeSpan SR is equipped with wheels, which facilitate positioning and make it easier to clean the room. The high performance FreeSpan UltraTwin facilitates lifts up to 880 lbs. The patient can be lifted in a seated or horizontal position and can even be positioned during the transfer.
[list] [*] Lift rails in several different lengths. [*] Simple height and width adjustment. [*] Made of aluminum; the right choice for environment, quality and design. [/list]
Maximum load: 550-1100 lbs (250-500 kg)
