Philips - UltraFill
by Philips
Oxygen Concentrator
UltraFill is an advanced home oxygen system that combines a stationary oxygen concentrator, filling station, and high-capacity 3,000 PSI cylinders to meet the needs of a wide range of oxygen patients, including those who are highly active or require continuous flow oxygen. UltraFill also has the needs of homecare providers in mind with features intended to save money by using existing inventory and lowering operating costs. [u]3,000 PSI Cylinder Advantage[/u] Long-lasting 3,000 PSI cylinders provide high-usage oxygen patients with >40 percent more oxygen than similar sized 2,000 PSI cylinders.
0RepliesTue Dec 06 2016 | Service Manual or Schematic? Is there a service manual or schematic available for the Ultrafill? Thanks! Reply |
0RepliesTue Dec 06 2016 | Service Manual Is there a service manual available for the Ultrafill? Reply |
0RepliesSat Aug 06 2016 | Types of cylinders allowed? As a private user, using the Philips Ultrafill and Millennium M10 (4 ltrs), are we ok to fill E-Tank cylinders or only the M classification cylinders? Alpine Home Medical has provided me with these products and with E-Tanks, 3000 psi. However, I am hearing a beep every 3 seconds, no yellow or red lights. This began about 1 1/2 hrs after installation today. I have put a call into Alpine to create a troubleticket, but also wanted to check with you about the E-Tanks and possibly the beeps every 3 seconds. My priority question in this email is the E-Tank issue. Thank you, m Reply |
| Height | 25.5 in |
| Length | 9 in |
| Weight | 45 lbs |
| Width | 20 in |
