Philips - EverFlo
Oxygen Concentrator
EverFlo is part of the Freedom Series of oxygen therapy products from Respironics designed to deliver clinically superior treatment and more freedom - freedom from worry, freedom from deliveries, freedom from complicated maintenance. Most importantly, the Freedom Series frees patients of some of the more demanding aspects of oxygen therapy. Until now, oxygen concentrators have been very similar - heavy, bulky, noisy, or require frequent maintenance. But EverFlo from Respironics is a unique stationary concentrator that delivers the features homecare providers want and patients deserve.
FORUMSView All (17)
0Replies2 years ago | Works but steady alarm Hi All, My Everflo oxygen concentrator seems to work but after running for a couple minutes I get the steady red light and aural alarm in addition to the green light. It has air flow and the valves are switching. No air leaks or kinked tubing. Does anyone know if this is something I can ignore or what's the cause? No service center or dealer anywhere nearby so I'd have to send it off; rather avoid that. Thank you, Rick AReply |
0Replies3 years ago | Continue red light on Iam using philipa everflo oxygen concentrator when iam on the power button it give continue beep with red lightReply |
0Replies3 years ago | Need EverFlo Service Tool I am checking an overflo with continous alarm and red LED. I HAVE CHECK the pressur, well its OK. For that I need EverFlo Service Tool and Manifest ZIP to perfom some control. Thhx in ADV Reply |
- Compact, ergonomic design takes up less space, looks less like a medical device
- One of the quietest mainstream concentrators
- No homecare provider filter change for two years
- Uses less power and produces less heat, so it’s more patient-friendly
- Easy to store and transport
- Low maintenance
- Quiet
- Simpler for patients to use and maintain
Height | 23 in |
Length | 9.5 in |
Weight | 31 lbs |
Width | 15 in |
- Oxygen Concentration(at 5 LPM):93% (+/- 3%)
- Liter Flow:0.5-5 liters per minute
