Slitlamp Microscopes - MS-101
by Slitlamp Microscopes
This is a slitlamp microscope as used in the field of optometry for eye examination. It is a more basic and consequently, inexpensive unit compared to the other equipment and is more suitable for use in an optometry eye clinic than for ophthalmic use in a hospital. The magnification is selectable between 10x and 16x. It has an optional R and T type applanation tonometer as well as has an option for a measuring eyepiece. The lens is made from high quality imported German glass for reduction in lens aberration. All optics are multi-coated and include mildew-proof and antireflection coatings. This slitlamp microscope is made in a US FDA (Food and Drug Administration) registered manufacturing facility as well as has CE certification.
1ReplyMon Oct 29 2012 | ms 101 slit lamp Who makes this instrument? Reply |
Field of View (mm): 18mm dia., 14.5mm dia. Range of Pupil Distance (mm): 55 - 82 Slit Width (mm): 0 - 9 adjustable Slit Height (mm): 1 - 8 adjustable Slit Angle: 0 – 180 Degrees
