Slitlamp Microscopes - MS-102
by Slitlamp Microscopes
This is a slitlamp microscope used for ophthalmology and eye examination. The magnification is selectable between 10x, 16x and 25.6x. The 25.6x magnification is obtained by using the included 16x eyepiece pair. It has an optional R and T type applanation tonometer as well as has an option for a measuring eyepiece. The lens is made from high quality imported German glass for reduction in lens aberration. All optics are multi-coated and include mildew-proof and antireflection coatings. This slit lamp microscope is made in a US FDA (Food and Drug Administration) registered manufacturing facility as well as has CE certification.
Field of View: 18mm dia., 14.5mm dia., 11.5mm dia., 9mm dia. Slit Width (mm): 0 - 9 adjustable Slit Height (mm): 1 - 8 adjustable Slit Angle: 0 – 180 Degrees
