Slitlamp Microscopes - MS-103
by Slitlamp Microscopes
OPHTHALMOLOGY SLIT LAMP MICROSCOPE
This is a slit lamp microscope used by ophthalmologists in the field of ophthalmology for eye examination. The magnification is selectable between 6x, 10x, 16x, 25x, and 40x. The included eyepiece pair is 12.5x. It comes with optional R and T type applanation tonometers as well as an optional measuring eyepiece. Another option is a beam splitter, ccd camera adapter, and ccd camera for taking the video image to a cctv monitor for all in the room to see, or for the ophthalmic examination to be videotaped. Another useful option is an extra monocular teaching tube, allowing a third observer/assistant to view the ophthalmic eye examination simultaneously. The lens is made from high quality imported German glass for reduction in lens aberration. All optics are multi-coated and include mildew-proof and antireflection coatings. This slitlamp microscope is made in a US FDA (Food and Drug Administration) registered manufacturing facility as well as has CE certification.
Field of View: 6x (33mm dia.), 10x (22.5mm dia.), 16x (14mm dia.), 25x (8.8mm dia.), 40x (5.5mm dia.)  InterPupillary Distance (mm): 55 - 75  Slit Width (mm): 0 - 9 adjustable  Slit Angle: 0 – 180 Degrees
