Stryker - Gynnie
OB/GYN StretcherBuilt on Stryker’s trademark features, Gynnie’s dual-purpose stretcher offers superior versatility through durable OB/GYN features integrated into a general use design. The Stryker Gynnie incorporates smart engineering to create a solution that is exceptionally easy to use. Innovative features and intuitive operation combine to not only promote usefulness, but also add efficiency in a wide range of applications.
2Replies4 years ago | Shipping Weight Stryker 1061 Gynnie Stretcher I can't find specifications that show the shipping weight. I had 400 lb. A freight carrier is trying to say it was 1,053 lb. We know that's way off. Thank you. Reply |
[list] [*] Adjustable footrests feature simple,one-handed operation [*] 4" thick Ultra Comfort mattress provides unparalleled support [*] Sealed mattress and clean lines prevent fluid collection [*] Compact design with pop-up push handles and retractable fifth wheel improves maneuverability [/list]
Height | 22.5 to 36 inches |
Length | 81.5 in |
Width | 31.5 in with siderails up |
Litter Positioning: Backrest 0° - 90° Foot Section 0° - 90° Trend./Reverse Trend. ±18° Patient Surface: 26" x 77" (66 x 196 cm) Siderails: 13" x 39" (34 x 99 cm) Caster Diameter: 8" (20 cm)
