Welch Allyn - Sure Temp Plus 690
Easy to use with intuitive operation, reduces the risk of cross-contamination with removable probe well and provides more reliable readings.Easy to use with intuitive operation, reduces the risk of cross-contamination with removable probe well and provides more reliable readings with improved accuracy. Takes approximately 4-to-6 second oral temperatures, 10-second axillary and rectal temperatures and 15-second adult axillary temperatures.
FORUMSView All (9)
1Reply5 years ago | Error 4.8 (unit not calibrated) hi guys, Has anyone encountered the error 4.8 and was able to defeat it somehow? It says the unit is not calibrated so I am thinking it is basically dead unless in warranty. I was curious if anyone has ventured to try to resolve the issue somehow though.. Let me know if you have worked into this error if you have looked into it. I talked to Welch Allyn who tell me they will swap thermometers with me for $162. Thanks in advance! I am wondering if there is something I can do to bypass this action though, and am looking for any actions you guys have taken along that line. mrstan!Reply |
3Replies6 years ago | Cleaning and Instuctional Manual I need the Cleaning and Instructional Manual for the Welch Allyn Sure Temp Plus 690Reply |
0Replies6 years ago | Cleaning and Instuctional Manual I need the Cleaning and Instructional Manual for the Welch Allyn Sure Temp Plus 690Reply |
- Interchangeable, removable probe wells reduce the risk of cross-contamination
- Large LCD displays temperatures in Fahrenheit or Celsius
- Last temperature recall
- Convenient storage for 25 probe covers
- Takes approximately 6,000 readings on 3 AA batteries
Height | 8.46 in |
Length | 2.43 in |
Weight | 12.6 oz |
Width | 3.18 in |
