Chattanooga - 3D Active Trac
by Chattanooga
The 3D ActiveTrac® is a unique table for back and neck pain treatment that adjusts to fit a wide variety of patients. Set-up is quick and easy since no ropes or pulleys are required. The angle of the cervical assembly can be adjusted from -20 to 30 degrees to accommodate every patient’s needs.
0Replies7 months ago | "Table needs servicing" message appears during lumbar cycling. "Table needs servicing" message appears during lumbar cycling. I've tracked the problem a bit. It seems like the pneumatic regulator is not getting the signal to open up and let the air pass through from the compressor to the rest of the system. This signal is however seen when using the cervical function because it opens up just fine. I can also see the signal with my multimeter coming from the analog module when in cervical mode. Has anyone else seen this issue? Thanks. Reply |
0Replies13 years ago | LUMBAR TRACTION DOESN'T WORK When using the lumbar traction the lumbar section would not move and then all of a sudden pop wide open, it doesn't close on the rest phase, it doesn't close when the time is up. Have to play with the lock turning it on and off to get the lumbar section closed. Reply |
[list] [*] Table accommodates the pain posture of the patient [*] Patient comes into the clinic with limitations; this table can assist with making therapy more comfortable via the flexion and oscillation capability [*] Table facilitates the incorporation of manual techniques with traction [*] Cross between manual therapy and mechanical traction (strikes a balance) Flexible Treatment [*] Incorporates rotation [*] Table is motorized versus a rope pull [*] Can be used simply as a mobility table [*] Treatment can start by moving the table as part of mobilizing the patient [/list]
