CORPAK Medsystems - CORFLO Feeding Tubes
CORPAK, Enteral Devices, offers a complete range of products to fit specific clinical needs in the hospital, nursing home and home care markets.CORPAK, Enteral Devices, offers a complete range of products to fit specific clinical needs in the hospital, nursing home and home care markets. Our extensive array of sizes allows treatment of the widest range of patients, from the smallest neonates to largest adults.
CORPAK MedSystems' patented enteral devices include CORFLO Feeding Tubes and FARRELL pressure relief valves.
CORFLO Enteral Feeding Tubes from CORPAK MedSystems offer advantages to your patients unlike any other feeding tubes available. CORPAK MedSystems' feeding tubes are the standard by which all other feeding tubes are measured!
0Replies6 years ago | hOW TO ACTIVATE LUBRICANT BEFORE REMOVING STYLET The CORFLO instruction leaflet figure #7 says activate the internal lubricant before removing the stylet. How do I do this?Reply |
- Patented ULTRA anti-clog outlet port significantly reduces the occurrence of clogging.
- The largest selection of adult, pediatric and neonatal feeding tubes to allow one-stop sourcing for all your feeding tubes hospital or system-wide.
- Patented TRAK feeding tubes: The ONLY feeding tube that can be used with the CORTRAK Enteral Access System.
- CORFLO Anti-IV prevents inadvertent feeding into an IV line. Compatible only with oral tip syringes for pediatric and neonatal use.
The Ultimate in Patient Safety:
- All CORFLO feeding tubes are printed with centimeter marks for increased patient safety and intubation accuracy.
- The entire CORFLO polyurethane feeding tube line is color coded to correspond to varying lengths.
- Stylet lengths are matched to the CORFLO feeding tubes.
- Clinician Convenience and Patient Comfort:
- Flow-through stylets to flush, auscultate and aspirate during the insertion procedure.
- Water activated lubricant on all polyurethane feeding tubes for greater patient comfort during intubation and effortless stylet removal.
- 100% radiopaque for X-ray confirmation.
- Weighted tubes use multiple tungsten weights allowing for flexibility and greater comfort during intubation.
- "Y" ports on all CORFLO polyurethane feeding tubes minimize touch contamination and make flushing easy.
- CORPAK MedSystems' feeding tubes are the standard by which all other feeding tubes are measured!
