Covidien - Kangaroo ePump
by Covidien
Enteral Feeding Pump
The Kangaroo ePump is a simple-to-use, precision enteral feeding pump. It is easily programmed to deliver continuous or intermittent feeding and can provide automatic flushing capability when used with Kangaroo ePump Enteral Feeding Pump feed and flush sets.
FORUMSView All (33)
-gworkg
a month ago
PM Certification Test
What is the certification
Equipment: Covidien - Kangaroo ePump
-sebastiandiaz
7 months ago
FEED ERROR help
Hello
My question is about error in the kangaroo epump.
The alarm sounds every 5 ml and says “Feed Error” but everything is installed correctly. What is the reason for this constant failure every 5 ml?
I'd appreciate your help
Thank you so much
-sebastiandiaz
7 months ago
ERROR KANGAROO EPUMP
Hola
Mi pregunta es sobre un error en la bomba canguro.
La alarma suena cada 5 ml y dice "Error de alimentación" pero todo está instalado correctamente. ¿A qué se debe este fallo constante cada 5 ml?
Agradecería tu ayuda
Muchas gracias
  • Attitude Independent - Pump set drip chamber has been eliminated which alleviates the hassle of keeping pump in an upright position and is ideal for hospital, home care, nursing home and ambulatory use
  • 72 Hour History- The Kangaroo ePump enteral feeding pump gives the clinician the ability to accurately track the amount of formula and fluid delivered to a patient ensuring the prescribed formula and fluid is received by the patient
  • DEHP-Free Pump Sets
  • Anti Free-Flow Pump Sets
  • "ATM-Style" Interface
  • The "Smart" technology identifies the pump set and allows programming for only that type of pump set
Weight2.3
Auto-Priming: 30 Seconds
Battery Life: 15 hours
Accuracy: +/- 10%
Flush Rate :   1960 ml/hr (maximum)
Flow Rate:  1-400 ml/hr (1 ml increments)
Flush Interval:   1-24 hr(s) in 1 hr increments
Voltage :   Operates on 9V DC, 1.5 Amps. Use AC adapter for wall outlet usagers
