Covidien - Kangaroo ePump
by Covidien
Enteral Feeding Pump
The Kangaroo ePump is a simple-to-use, precision enteral feeding pump. It is easily programmed to deliver continuous or intermittent feeding and can provide automatic flushing capability when used with Kangaroo ePump Enteral Feeding Pump feed and flush sets.
FORUMSView All (36)
-Dennis Balow
Fri Aug 15 2025
Recertification Sets
Has anyone been able to find recertification sets? They have been on back order for quite some time.
-BrianC_NJ
Thu Jan 09 2025
Feed errors
I'm at a facility that has about 20 ePumps. With 4 of them I keep getting Feed Errors. Everything in the manuals says that feed errors are due to an issue with the lineset. I've tried multiple sets & tried them on multiple pumps. I'm confident that the lineset isn't the problem. Is there anything with the pump itself that could cause Feed Errors?
-KathyeK
Sat Apr 20 2024
Language
I'm having trouble with setting up language.  In the setup the arrow pointed to English but it looks like Greek to me and I'm stuck!
Equipment: COVIDIEN Kangaroo Flush and Feed Pump
  • Attitude Independent - Pump set drip chamber has been eliminated which alleviates the hassle of keeping pump in an upright position and is ideal for hospital, home care, nursing home and ambulatory use
  • 72 Hour History- The Kangaroo ePump enteral feeding pump gives the clinician the ability to accurately track the amount of formula and fluid delivered to a patient ensuring the prescribed formula and fluid is received by the patient
  • DEHP-Free Pump Sets
  • Anti Free-Flow Pump Sets
  • "ATM-Style" Interface
  • The "Smart" technology identifies the pump set and allows programming for only that type of pump set
Weight2.3
Auto-Priming: 30 Seconds
Battery Life: 15 hours
Accuracy: +/- 10%
Flush Rate :   1960 ml/hr (maximum)
Flow Rate:  1-400 ml/hr (1 ml increments)
Flush Interval:   1-24 hr(s) in 1 hr increments
Voltage :   Operates on 9V DC, 1.5 Amps. Use AC adapter for wall outlet usagers
