Covidien - Kangaroo 924
Enteral Feeding PumpThe Kangaroo and trade 924 Enteral Feeding Pump features pre-set volume and overflow infusion safeguards to ensure the correct and consistent delivery of nutrition. The easy-to-use controls make set-up and operation of the unit intuitive. The Kangaroo and trade 924 pump is used exclusively with the Kangaroo and trade 924 pump sets.
FORUMSView All (5)
2Replies2 years ago | PM for Kangaroo 924 Hello, does anyone have info on the PM procedure, particularly the occlusion specifications? I've seen nominal occlusion listed at 15 psi and also 12 but no tolerances were included or flow rate settings. Not sure if it should be 12 psi max or 12-15 psi. I have not been able to locate a service manual. Reply |
1Reply5 years ago | user maual user manual Reply |
1Reply7 years ago | Language How do I change the language Reply |
- Intuitive Interface - Clearly designed and visible programming options allow for quick understanding of the programming features to help reduce the potential for programming errors
- Dial Control- Permits quick and easy programming of feed rate and Volume to be Delivered (VTBD) to provide a smooth and easy transition from the Kangaroo™ 224 pump
- Operating Range in Individual (one mL) Increments- Allows for quick, easy and exact programming of feed rate (1 to 300 mL/hour) and VTBD (1 to 2000 mL)
- Built in Pole Clamp- Reduces overall weight and makes the pump less bulky and easier to use when attached to IV poles
- 16 Hour Battery Life - Permits extended function and power ability (based on 125 mL/hour feed rate) . The battery will charge when the AC Adapter is plugged into an outlet. Total time to charge the 924 pump is approximately 8 hours. Battery life is determined based on 125mls per hour feed rate.
- Quick Battery Recharge Rate- Battery charges in approximately 8 hours when the AC adapter is plugged into an active outlet
- Memory- Maintains flow rate settings for up to 16 hours (battery operation) or 24 hours (AC connected). This allows for simplified use and minimizes potential for errors in provider programming. When powered on, the pump automatically reverts back to previous settings within this time range.
- Audible and Visual Alarm- Six different function alarms include both audible and visual alarms. These alarms provide for additional safeguards and reinforced clinical confidence. The added visual alarm provides for a greater sense of patient safety, especially in Home Care markets.
- LED Display - Provides for clear and easy programming ability and visibility in all lighting conditions
- Clear Indicator Lights - Clear type and visual display provide for easy feeding pump operation without lengthy specialized training. Indicates for AC connectivity and Vol Clear.
- Adjustable Languages - Available in 13 different language selections
- No Removable Parts- The Power Cord and IV pole clamps are both integrated into the unit
- Light Weight and Portable - Weighing only 3.75 lbs, the pump is convenient, light-weight, and easy to transport. The built-in pump handle also provides for greater flexibility and easy movement.
- Accuracy - This pump is accurate to within +/-10% (or 0.5 mL, whichever is greater)
- Unique OPTIX Sensor - The innovative, patented OPTIX sensor utilizes optical sensors to confirm proper pump set placement. This unique feature provides for safeguards against improper placement and results in increased patient safety.
Height | 7.25 in |
Length | 4.33 in |
Weight | 3.89 lbs |
Width | 6.61 in |
