Kendall - Genius 2
by Kendall
The Genius™ 2 thermometer uses its proprietary Peak Select System technology to determine the body's accurate temperature directly from the tympanic membrane. Count on Genius™ 2 thermometer to deliver an accurate temperature while saving staff time, minimizing infection control concerns and ultimately paving the way for better patient care
0RepliesSun Sep 28 2014 | temperature readings what is the normal temperature readings Reply |
1ReplyMon Sep 16 2013 | Genius 2 Tympanic IR thermometers Any body know, anyone who does calibration on these units? Reply |
[list] [*] Tapered Probe Design Facilitates proper alignment with the ear canal [*] Tip Based Sensor Technology Improves accuracy and repeatability and minimizes the need for recalibration [*] Peak Select System Records & analyzes up to 100 measurements per scan [*] Rapid Response Time Easy to Use [*] Programmable Display Allows the thermometer to be customized according to hospital protocol [*] No-Touch Probe Cover Enhanced infection control [*] Real Time Temperature Accurate readings to improve clinical outcomes [*] F°/C° Toggle Button Customize temperature read outs to follow facility protocol [*] Pulse Timer Convenient for pulse and respiration monitoring [*] Extended Battery Life Takes 15,000 readings on 3 AA batteries [*] Easy Load Probe Covers (Thermometer) Ease of Use [*] Easy Load Probe Covers (Base) Quick and Easy Loading [*] ASTM and CEN Compliant Ensures accuracy and dependability [*] FAC System (Fast Ambient Change) Ensures accurate reading in fluctuating ambient temperatures [/list]
