Covidien - Filac 3000 EZ
by Covidien
The Filac™ 3000 EZ electronic thermometer
The Filac™ 3000 EZ electronic thermometer utilize advanced technology to provide the industry's most accurate and fastest readings in multiple easy-to-use formats.
-mato
10 years ago
axillary temperature / température axillaire
Translation of original post:
Hello, I use this thermometer in hospital recently and I wonder about the différenece between the result of axillary and rectal temperature. We must add +0.5 ° or not knowing that in my service one has to use other equipment for temperature? Thank you in advance
Originial post:
bonjour, j'utilise ce thermometre depuis peu en hospitalier  et je m'interroge sur la différenece entre le résultat d'une température axillaire et rectal . Doit on rajouter + 0,5 ° ou pas sachant que dans mon service on est amené à utiliser d'autres équipements pour la température?merci d'avance
Fastest Predictive Readings
  • 3-5 seconds Oral Quick Mode
  • 6-10 seconds Standard Mode
  • 60-120 seconds Direct Mode
    Easy to Use
  • Intuitive icon based user interface
  • Easy to read LCD display with backlight
  • Durable, robust design; stands upright on a flat surface
