CYBEX - PRO3
Treadmill
The Pro3 Treadmill is a club owner’s dream machine. Its unmatched durability makes it the energizer-bunny of treadmills – it just keeps on going after many of our competitors’ machines have stopped.
- Programmes: In addition to a broad variety of programmes the CYBEX Pro3 treadmill has a live keyboard. The programme or any of its settings can be changed while in the programme without having to start over.
- Split Level Display: The console itself has been designed to match the way a treadmill is used. By separating the console into two parts, users are given the ability to use what they want and when. Time, speed, and incline are constantly visible on the lower level with other information on the top.
- Pulse Width Modulation (PWM) controller: Using digital feedback, the controller uses PWM technology for high-speed stability and constant speed control with smooth operation. It also maximises effectiveness for economical power consumption.
- Safety Sentry: Knows whether you are there or not and will stop the belt after the pre-selected waiting period helping to keep members secure.
- Self-Serve Deck: CYBEX engineering has developed the lowest maintenance deck in the industry and it is standard on the Pro3 treadmill.
- Deck Suspension: The Pro3 treadmill running deck is soft at landing, hard in the middle, and rigid at toe-off, to precisely match the body mechanics of a runner.
- Manual Mode: YES
- Integrated AV controls: Semi integrated audio and visual controls on display channel for volume selection
- Replaceable headphone jack: YES
- Connectivity: Provided by CSAFE (Fitlinxx® certified)
- Convenience features: Split-level consoles, two water bottle sized holders, magazine rack and tabs and a utility tray
- Safety:Permanently attached lanyard with removable key
- Languages: 7 languages (English, French, German, Spanish, Japanese, Russian, Swedish)
- Max User Weight: 182 kg
- Weight: 173 kg
- Dimensions (L x W): 206 x 81 cm; Step-up Height: 19 cm
- Warranty: 10 year - frame, 3 year - parts, 1 year -labour, 1 year - deck/belt
