CYBEX - CX-445T
Treadmill
The CX-445T is a full blown commercial treadmill that wont blow your budget or your floor plan. To be compact and affordable. The full-sized running surface is delivered in a compact footprint. Although it is 10 shorter than most commercial treadmills, the CX-445T still provides a 20 × 60 running surface. In addition to an attractive purchase price, the low maintenance costs help make the CX-445T the value purchase gyms love. [ Even without an instructor. The streamlined operation of the display provides direct use of Quick Start and intuitive access to the nine available programs. The Cool Down feature presents a two-minute cool down at the press of the button. The dual water bottle holders and utility tray keep items users rely on right at their fingertips. [So smart it matches the runners stride. Our Intelligent Suspension (IS3) deck is not like traditional floating decks which can cause instability in a runners stride. The IS3 absorbs the impact of landing where it occurs. Its soft at landing, hard in the middle, and rigid at toe-off to exactly match the body mechanics of a runner. And ... the dual level design of the CYBEX 445T lets you see the IS3 at work. The CX-445T is built with solid steel construction that gives it the same sturdy feel as the more expensive models. The 3.0 HP motor combines with rugged 3.0 diameter rollers to provide exceptionally smooth and reliable operation at all speeds. The waxed-marine hardwood deck is double sided for extended life and needs no external lubrication.
FORUMSView All (4)
0Replies8 years ago | cybex 445t The off is showing on the display what can be the causeReply |
0Replies10 years ago | Safety switch inoperative The Safety switch is inoperative, in other words it doesn't stop the treadmill. Has anyone had this problem ? I know it has a magnetic switch and that may be the culprit. Does anyone know where I can get an "actual" schematic of the circuits not just the diagram ? Thank you, galustig@yahoo.com Reply |
1Reply11 years ago | price
Reply |
- Compact: The full sized running surface is delivered with an ultra compact footprint that emphasizes the user experience. The elegant low profile hood design provides an unobstructed path for the user’s stride which maximizes the usable running area.
- Durable: The 3.0 HP motor with PWM control combines with rugged 3.0” diameter rollers to provide exceptionally smooth and reliable operation at all speeds. The waxed-marine hardwood deck is double sided for extended life and needs no external lubrication.
- Comfort: Our Intelligent Suspension 3 (IS3) deck suspension system flexes primarily at the point of impact, absorbing shock where it occurs to provide an exceptionally comfortable experience unlike the traditional floating decks which indiscriminately give way and cause instability in a runner’s stride. The dual-level design of the base lets you see IS3 at work.
- Convenience: The streamlined operation of the display provides direct use of Quick Start and intuitive access to the nine available programs. The Cool Down feature presents a two-minute cool down at the press of the button. The dual water bottle holder and utility tray keep everything at your fingertips
