CYBEX - LCX-425T
Treadmill
LIGHT COMMERCIALThe LCX-425T is a treadmill that provides a commercial-sized running surface in a space saving footprint. Perfect for the upscale home and residential condominium but durable enough for the hotel gym or corporate fitness facility. SPACE SAVER Commercial sized running surface in a compact footprint. The open front design means the hood cover doesnt get in the way of a natural stride and the unobstructed path maximizes usable running area. SMOOTH AT ANY SPEED Just like the big guys. The 3.0 HP motor with Pulse Width Modulation (PWM) combines with rugged 2.75 rollers to provide exceptionally smooth operation at all speeds. The solid steel construction provides a vibration-free operation and the feel of stability usually available only in the most expensive models. INTELLIGENT DECK So smart it matches the runners stride. Our Intelligent Suspension (IS3) deck is not like traditional floating decks which can cause instability in a runners stride. The IS3 absorbs the impact of landing where it occurs. Its soft at landing, hard in the middle, and rigid at toe-off to exactly match the body mechanics of a runner. And ... the dual level design of the CYBEX LCX-425T lets you see the IS3 at work. ENGINEERED FOR CONVENIENCE All the little details. At hand convenience with split-level consoles (designed to match the way you use a treadmill), two water bottle sized holders, magazine rack and tabs, and a utility tray.
0Replies9 years ago | No power! Yesterday we moved the 425T from our gym to our home. We didn't drop it, were very careful in the transit but I've plugged it in and I get nothing in terms of power. Tried different outlets, etc. I feel like a knucklehead! Checked every connection within the unit that I can but can't identify any reason nothing will come on the display. No lights; no nothing. Reply |
1Reply13 years ago | lcx-425t e1, e6 problem can not get into service mode to calibrate the tredmill. I have service manual also but luck. pls help. bro.ge62@hotmail.comReply |
- Heart Rate: Includes Contact and Wireless capability (chest strap not included). Multi-color heart shaped LED provides color coded feedback of heart rate
- Deck: IS3 Intelligent Suspension System
- Programs: 10 standard, 9 custom, 5 fitness
- Self-Serve Deck: CYBEX engineering has developed the lowest maintenance deck in the industry and it is standard on the 425T treadmill. And ... the double sided deck can be rotated and flipped giving up to four surfaces to maximize deck life.
- CoPulse Width Modulation (PWM) controller: Using digital feedback, the controller uses PWM technology for high-speed stability and consistent speed control with smooth operation. It also maximizes efficiency for economical power consumption. .
- Display Readouts: 7x15 matrix display of profile with LED readout of time, speed, incline, distance, calories, Calories/hr, METs, Heart Rate.
- Added Features: Split-level consoles, two water bottle sized holders, magazine rack and a utility tray. Dual speed personal fan.
- Dimensions: 72" x 32" x 61"
- Weight: 320lbs
- Motor: 3.0 HP (peak) brushless AC drive Commercial Duty
- Running Area: 60" x 20"
- User Capacity: 350 lbs
- Speed: 0.5 - 11mph
- Incline: 0% - 15%
- Heart Rate: Includes Contact and Wireless capability (chest strap not included). Multi-color heart shaped LED provides color coded feedback of heart rate.
- TV: LCD TV optional
