CYBEX - 750R
by CYBEX
Versatile recumbent bike for the fitness enthusiast who demands CYBEX performance with the comfort of a wider seat base and supported back.
Versatile recumbent bike for the fitness enthusiast who demands CYBEX performance with the comfort of a wider seat base and supported back. The 750R bike offers both performance variety for the user and unparallel durability for the gym owner. And ... the 750R has the same high tech look of the rest of the CYBEX cardiovascular family of products to create a gym that looks like it belongs together. Even though users vary in size, weight, and fitness goals... only one bike will give them all the workout they are looking for... the CYBEX 750R.   [b]   BEGINNER TO OLYMPIAN[/b]    The lowest starting level and the highest resistance. For those who never rode a bike before and those who are preparing for the Olympics, the CYBEX 750R is the perfect piece of equipment to train on. The most deconditioned user or rehab patient can use it safely because of the low power input requirement (20 Watts) and it goes up to 900 Watts (to make a grown man cry). All possible because of the CYBEX self-tensioning drive. Belt tension is important because a lot of belt tension is needed to create a high power training tool. But... belt tension creates drag... and drag can drive up heart rate for beginning cyclists. The answer is the CYBEX self-tensioning drive.       [b]ONE BIKE - MANY PROGRAMS [/b]   Ride outside or train for the Tour de France. This is the most unique bike in the industry. With three modes of operation and 21 programs with 21 levels, personal trainers love it in Constant Power mode. Isokinetic mode is for serious athletic training and rehabilitation training. The Bike Mode is just like a Sunday afternoon bike ride. Click to view Why it Works.       [b]DETAILS[/b]    Little things add up to a big difference. We’ve thought of a lot of details that both users and owners appreciate. Multi-position design of handle bars accommodates riding styles from upright to aero with two sets of contact heart rate grips so HR can be monitored in any position. The optional Personal Entertainment Monitor with iPod compatibility turns itself off to save energy and prolong monitor life. REALLY IMPORTANT is the walk-through design that makes the 750R perfect for seniors and rehab applications.       [b]RUGGED DURABILITY[/b]    For low maintenance. With a welded frame made from forged steel, the CYBEX 750 bikes have a three piece heavy duty mountain bike crank that makes them durable enough for rugged mountain terrain. In a gym setting, this construction translates to low low low maintenance. And … CYBEX engineers even designed the enclosures so that sweat is directed away from the bike mechanism.
FORUMSView All (5)
-Hishers
Thu May 09 2024
How to Change km to miles?
How to change km to miles?
Equipment: CYBEX - 750R
-Hishers
Thu May 09 2024
-Cybex750R
Wed Mar 21 2018
Inoperable
Need advice about Out of OrderShowing on screen.Reply
[list]  [*] Pedal Design - Extra wide double sided pedal design accommodates any size foot. The easy to adjust pull strap buckle closure gives users the comfort they seek. [*] Resistance Range - The 750R's wide range of resistance (from 20 to 900 watts) can create a challenging or modest exercise experience. 20 Watts is much lower than most other bikes on the market and is important for de-conditioned users. 900 watts "can make a grown man cry" - quote from a veteran cyclist.    [*] Handlebars - Multi-positioned handlebars promotes a comfortable hand position with HR grips where they are most convenient.  [*] Seat Engineering - A CYBEX proprietary seat was designed by cyclists to provide comfort for the long ride. You need 3 things: as much surface area as possible for support in the proper areas - while allowing full range of leg motion - while being kind to between the legs - and only CYBEX has it.On a CYBEX bike riders really can work up a sweat so the seat back is designed with holes for optimized ventilation to keep you cool on any length of ride.  [*] Front wheels - Because bikes are more mobile than many other exercise machines, they don't stay in the same place all the time. The 750 cycles have wheels on the front for easy rolling so they can be moved around.    [*] Single Stage Drive - The self-tensioning single-stage drive and hybrid eddy-current self-generating brake provide high torque capabilities with exceptionally low drag to provide an exceptionally broad resistance range of 20 to 900 watts with superbly smooth operation.  [/list]
Height49.5
Length 63.5 in
Weight178 lbs
Width25 in
Max User Weight: 400 lbs. (181 kg)
