Baxter - Flo-Gard 6201
by Baxter
Can deliver a wide variety of fluids over a broad range of infusion rates
The Baxter Flo-Gard 6201 Infusion Pump single and dual-channel infusion pumps are all-purpose IV pumps that use standard IV administration sets from Baxter. The pumps feature automatic piggybacking, upstream and downstream occlusion detectors, air-in-line detection, automatic restart after occlusion clears and IV set free-flow protection.
Flo-Gard pumps are currently only serviced by Baxter in Latin America
FORUMSView All (88)
-jason@elitebiomedical
Tue Oct 22 2024
Keypad Issues
My Baxter Flo-Gard 6201 Pump "Silence, Pri Start and 5" Buttons are not working. Anyone else ever had this issue?
-tmlee
Wed Sep 22 2021
Check loading set error/alarm
I have a baxter flogard 6201 pump that is constantly showing check loading set error/alarm after loading, despite the set being loaded correctly and multiple attempts. Any suggestions or ideas? Reply
2
-Randy19
Mon Apr 12 2021
Error message
I'm getting a F_38 error code when I power on this pump.Reply
  • Pumps a wide variety of fluids, including blood and fat emulsions
  • Suitable for use in epidural administration
  • Safety Clamp automatically occludes the tubing when the pump door is opened
  • Pre-Programmable, configurable
  • Easily replaceable fuse, battery, and power cord
Volume to be Infused1 to 99.9 ml
Height11.4 in
Length 5.1 in
Flow Rate Range1 to 99.9 ml/h
KVO Rate5 ml/h or programmed rate, whichever is less
Weight11.6 lbs
Width7.9 in
