GE HealthCare - Signa Excite 3.0T
by GE HealthCare
Provides highly detailed images that helps in evaluating a wide range of conditions, including stroke, cancer and musculoskeletal disease.
The G.E. Signa EXCITE 3.0T provides highly detailed images that helps in evaluating a wide range of conditions, including stroke, cancer and musculoskeletal disease. It was designed to increase image quality and resolution, while also increasing speed for enhanced productivity. It offers imaging volume with a 45 cm field-of-view imaging capability, which enables optimized neurovascular, orthopedic, and abdominal applications.
FORUMSView All (3)
-bcreech
Wed Mar 23 2016
GE excite application disk
Anyone have a  Signa Excite 11.1 M4 Applications disk image they could send me? I have the disk, but there are 2 scratches on it and it won't load.    mine shows 5304174 Rev 001 137926 USAReply
-jog
Wed Oct 28 2015
help needed on GE MRI signa excite 0.2 tesla
i have need  help on GE MRi Signa excite (0.2 Tesla) i have recently install this MRI after bootup console succesfully a message comes on errorlog area that "temperature controller communication is not established, retrying...." while on temperature meter current temperature is 32.5 i checked the serial cable comes from temperature meter to console it was ok what could be the reason i will very thankfull to you if you give me a good suggestion thanks regards jog (field service engineer)Reply
-MedwrenchAdmin
Wed Dec 01 2010
[post moved] Product Focus Radiology Market Analysis Magnetic Resonance Imaging
Moderator Action - This post has been moved. [url=/?home.readPosts/pagePostNo/1893/]Click Here to read the new thread.[/url]Reply
  • Double the magnetic field of 1.5T MRI [*] Ultra-compact 3.0 Tesla magnet (length: 200 cm (6.5 ft))
  • Patient weight limit of 159 kg (350 lbs)
  • Unique CT-like 60 cm (2 ft) Bore (tube) diameter with the highest levels of magnetic field homogeneity.
  • Magnet weight incl. Helium only approx. (12,000 kg (26,455 lbs))
Magnet TypeSuperconducting
Power Requirements480 VAC
Weight26455 lbs
Clinical UseWhole Body
Gantry (Max. Clearance) 60 cm
Magnetic Field Strength3 T
Patient Weight Capacity350 lbs
Magnetic Homogeneity: Yes Minimum Slice Thickness: 0.3mm Acoustic Noise Management System: Yes
NEWSView All
