Chattanooga - Hydrocollator E-1
Stationary Heating Unit
FORUMSView All (6)
3Repliesa year ago | Overtemp Tripping Hi, my E-1 Hydrocollator keep going in overtemp mode and stop heating. I already replaced the overtemp switch with a genuine part #20548 but it's still tripping. What do you think is the issue here? Thank You. Equipment: Chattanooga - Hydrocollator E-1 Reply |
3Replies4 years ago | Manual Is service manual available Reply |
7Replies5 years ago | Heater element What should be the resistance range for a healthy heater element? Unit continues to blow overtemp control.Reply |
- High quality stainless steel
- Thermostatically controlled temperature
- No plumbing required
Specifications Product Weight : 15 lbs (7 kg) Product Length : 13 in (33 cm) Product Width : 8 in (20 cm) Product Height : 16 in (41 cm) Shipping Weight : 17 lb (7.7 kg) Shipping Length : 15 in (38.1 cm) Shipping Width : 11 in (28 cm) Shipping Height : 18 in (45.7 cm) Mains Power : 110-120 VAC~, 50/60 Hz Safety Tests : CE, UL, cUL Electrical Class : Type B
