Cardioline - AR600
by Cardioline
Cardioline ar600 Portable Resting ECG Machine
The Cardioline AR600 resting ECG features wireless connection via the IR (infrared) digital interface. It has reduced weight and autonomy of more than three hours and 300 recordings. The system comes with the company's "Online" user guide, and the software is customizable. There are no restrictions or constraints, as the selection can be made either at the moment of purchase or later. Options available include a multi-channel option, an ECG measurements option and a PC ECG option.
FORUMSView All (6)
-Khalid Mehmood
a year ago
Hi I am Khalid from Pakistan and I have cardioline ar600 Ecg machine and giving single channel print. How can be change into 3 channel print.
Hi I am Khalid from Pakistan and I have cardioline ar600 Ecg machine. That is giving single channel print. How can be change into 3 channel print.
Equipment: Cardioline - AR600
-tdaisey
7 years ago
channel selection
How do you get 3 channels to print? There is no screen on my modle to referanceReply
-rafikHAJ
8 years ago
MODE AUTO
l'ECG n'imprime rien en mode AUTO
[list]   [*] Easy one touch automatic operation   [*] Alphanumeric keypad   [*] Advanced linear phase digital filters to eliminate interference without altering ECG morphology   [*] High definition digital thermal printer, no stylus, no moving parts   [*] Dual power supply, AC and internal rechargeable battery standard on all units.   [*] Copy capability - you can reprint the last ECG with different parameters, to get a better look at your tracings   [*] High quality durable patient cable and accessories   [/list]
EKG/ECG TypeRest
Height185 mm
Length 250 mm
Weight1000 g
Width60 mm
Power Supply: AC mains with external power supply 230V±10% 50/60 Hz.;   Battery Capacity: 3 hours, 300 recordings   Writing System: Thermal printer, 8 dot/mm Usable print height 50 mm   Operating Modes: Manual, Automatic, PC ECG   Input Dynamics: ± 300 mV @ 0 Hz.± 5 mV in pass band   Input Impedance: > 100 MW on each electrode   Common Mode Rejection: > 100 dB   Frequency Response: 0,05 - 150 Hz (-3dB)   Time Constant: 3,3 s   Pacemaker Recognition: Recognizes pulse in accordance with current IEC standards   Serial Interface: Infrared   Diagnostic Programs: Parameter calculation (optional)   Options: Multi-channel option, ECG measurements option, PC ECG option
