Chattanooga - 2402 Hydrocollator M-2
by Chattanooga
Hydrocollator® M-2 Mobile Heating Unit
These durable stainless steel water tanks house the Hydrocollator® Moist Heat HotPacs. The units are thermostatically controlled to ensure the ideal therapeutic temperature for HotPacs. Their lifespan in the clinic is almost indefinite!
FORUMSView All (24)
-Advanced Wellness Ctr
Wed Aug 20 2025
not heating up
Our HYDROCULLATOR M2 indicator light is off and after adding water it does not seem to heat up anymore. I only see a turn on & off switch. Anything else I can check/rest? We had some bad storms in this area last few days, outlet is working though.
Equipment: Chattanooga Hydroculator M2
-Kmbrack
Sat Oct 15 2022
Tighten elemnt
Our element is lose and is leaking
Equipment: Chattanooga - 2402 Hydrocollator M-2
-Hazzel
Wed Dec 29 2021
handle set
hi need part number for top door handle setReply
[list]         [*] Full fiberglass insulation to prevent heat loss         [*] Dependable, rugged stainless steel design         [*] Simple to fill with water. No plumbing required         [*] Constant temperature of HotPacs is maintained         [*] Mobile units are equipped with 8 cm swivel, rubber casters for friction free movement about the clinic         [/list]
Product Weight : 48 lbs (22 kg)          Product Length : 27 in (67 cm)          Product Width : 16 in (41 cm)          Product Height : 33 in (84 cm)          Shipping Weight : 93 lb (42.2 kg)          Shipping Length : 30 in (76.2 cm)          Shipping Width : 20 in (50.8 cm)          Shipping Height : 37 in (91.4 cm)          Mains Power :110~240 V 50/60 Hz          Safety Tests :EN 60601-1          Electrical Class :Class 1, Type B
