Bionet - CardioTouch 3000
CardioTouch 3000 Electrocardiograph ECGProviding a large LCD display and touchscreen operation, the CardioTouch 3000 is an efficient and cost-effective 12ch resting ECG. ECG reports, including detailed interpretation information, print on A4 full size paper for easy filing. Cardiotouch 3000 acquires 10 full seconds of ECG data simultaneously from 10 leads to produce an accurate 12 channel printout with analysis in under 60 seconds. CardioTouch 3000 combines menu-guided touch screen technology with a convenient rotary key to maximize ease of use. The CardioTouch 3000 uses normal fax paper which costs about ¼ the cost of ECG paper.
FORUMSView All (5)
1Reply4 years ago | Flat Lined Leads I can't seem to get certain leads to produce a rhythm. Its not the same leads every time. its usually 2 leads that don't produce a rhythm. I've tried cleaning the leads and making sure that they are properly placed and connected to the body with no success. Is there anything else that I can do to troubleshoot? Is this a common problem with this model? Please help.Reply |
0Replies6 years ago | Printing We can't get our CardioTouch 3000 machines to print. The machine works fine, screen picture is fine, but no printing. What can we trouble shoot? Reply |
1Reply6 years ago | Service and operators manual Where can I get a service & operators manual for a Bionet Cardiotouch3000?Reply |
[list] [*]Clinically Important Simultaneous 12 Lead Acquisition [*] Maximized Ease of Use [*]Built-In Memory [*]Enhanced Interpretation [*]Software Upgradeable [*]ECG Filing System “EKG PLUS II” [*]Low Maintenance Cost [*]A4 Full Size Paper [*]Supports Pediatric Diagnostics for ages 3 to 15. [/list]
EKG/ECG Type | Rest |
Height | 305.5 mm |
Length | 92.5 mm |
Weight | 3.5 kg |
Width | 296 mm |
User Interface Touch screen: (alphanumeric and symbol available), keyboard, rotary push-knob (pop-up menu) Patient data:ID, name, age, sex, height, weight Basic measurement:Heart rate, PR, QRS, QT/QTc, P-R-T axis
