Bionet - CardioCare 2000
by Bionet
CardioCare 2000 12 Channel Resting ECG
The CardioCare 2000 is an economically priced 12 channel resting ECG that does not compromise on performance. Suitable for use in private practice, ER, or hospital use, the CardioCare 2000 is designed for maximum ease of use and convenience. Through the modem interface the ECG data can be transmitted directly into the fax machine in the other area for the consultation. Also convenient PC-based operation environment is available with PC software "EKGPLus™".
FORUMSView All (8)
-Point Medical
10 years ago
Data
Data is not being interprted. Reading is flat line. How do we fix this problem? Anyone know?
-Randy Smedley
11 years ago
Cardiocare 2000 Service manual
Anyone have this manual.  Please email repsonses to smedley.randy@gmail.com
Thanks
-GFacciolo
11 years ago
QTc question
How does the cardiocare 2000 calculate the QTc?
[list]   [*] Simultaneous 12 Channel Resting ECG   [*] Over 80 kinds of interpretation results based on the advanced Minnesota Code   [*] A4 Full Size printouts in 1,3,6 and 12ch formats.   [*] Copy button generates ECG copies in any of the available formats   [*] Uses normal fax paper which costs about ¼ the cost of ECG paper   [*] ECG Filing System “EKG PLUS II”   [*]Software Upgradeable   [/list]
EKG/ECG TypeRest
Height305.5 mm
Length 92.5 mm
Weight2.98 kg
Width296 mm
ECG Leads: 10 lead 12 channel simultaneous 10-second resting ECG   Printing Speed: 12.5, 25, 50 mm/s   Display 2 x 16 character LCD display   LCD display/LED indicator:Sensitivity, speed, filter status, HR, printing form, rhythm lead signal quality, power source, battery   Keyboard: Membrane keyboard. Alphanumeric and symbol available   Patient Data:ID, name, age, sex, height, weight
